Hurricaneplanes
Hi to everyone from accross the pond as this is my first post. I have a Birchwood 25ft cruiser powered with a Volvo Penta AQ105 engine coupled to a Volvo Penta AQ100 Gear Leg. I need to remove the engine and leg from the boat so that I can fit a new transom. The gear leg is off. the cover plate's 6 bolts passing through the transom are off as are the 6 bolts holding the gear shaft plus its housing to the cover plate and then through to the engine bell housing. Now the problem is that I cannot see how to remove this gear shaft housing from the cover plate. I suspect that some corrosion has taken place between the two and I am seeking any advice as how to seperate them please. Would any member have any ideas please or even a workshop manual to either sell or even email the relevant details.
