One more dumb question. Can I take the zinc out while I match to a replacement without the boat sinking? (go easy on me - I just switched from 25 years of racing cars. Those I understand and when something went wrong it didn't go to the bottom of a river)Pull one of the old ones out, and take it with you. You'll find both 1/4" and 3/8" TP threads being used for these.
Couple of things that I have observed with these:
The brass pipe threaded section will always be OK and will always be tapered pipe threads.
However, I've found that the actual replacement pencil anode threads will vary from one manufacturer to another.
When you pick up the new anodes, purchase a hand full of extra pencil anodes. This way these will fit the brass portion in the future.
The other thing is the length.
Sometimes the H/E won't allow for a full length anode, and we end up shortening the anode as to prevent it from bottoming out and breaking when screwed in fully.
Jgreen, I agree with erich.
Open the end plates up and take a peek at the tube bundle.
Also, pull these pencil anodes part way through your season, and inspect them. You may find that they require replacement more than once per season.
A few pencil anodes per season is much cheaper than an H/E replacement.
And NO teflon tape on the threads... they must make continuity with the shell/tube.
