Nautique 1981
Check engine light issue
Replaced impeller a month ago and ran boat the next day with no issues.
Changed oil and filter Saturday. Took out the boat on Sunday. Check engine light came on when the boat started and remained on. Oil was right at the add level so added a bit more and came up to just below full.
Ran boat for maybe 5 minutes with the check engine light on. Oil pressure and temp was perfectly fine on the gauges.
Turned off boat and shut off batteries thinking it might reset the check engine light. Turned on motor again and check engine light still on. Ran at idle for maybe a minute. Then engine ran rough/bogged down for a couple seconds then shut off on its own.
Took about 40 min to an hour to get towed back to the dock. At the dock turned the motor on, check engine light was still on but ran fine at idle. Drive onto the trailer and shut it off.
1) is there anything that causes the check engine light to come on other than a temp issue or oil pressure issue? There wasn’t an alarm sounding, it was only the light.
2) could this be an oil pressure sensor of temp sensor?
3) could clogged fuel filters cause the motor to bog down? Doesn’t seem this would cause the check engine light though.
