"I am having a problem with th
"I am having a problem with this motor. The engine runs like a champ up to about 1600 RPMs then labors and bucks, spits and hesitates at the 1600 RPM mark. I have totally rebuilt my holley 650 carb, totally drained the gas tank and wiped clean, replaced all filters and even hooked to a auxillary fuel tank in case there was a problem in the tank. Checked compression and fuel pump pressure. I've isolated the exhaust in case there was an obstruction. I pulled the distributor to check for end play and inspected the centrifical advance, which was all OK. New cap, rotor points, condenser, coil and ballast resistor, plug wires and plugs The results are always the same. It seems that the misfires above 1400 RPMs are on the right bank of cylinders. I acts to me as if it is starving for fuel, but I have about 7 pounds of fuel pressure at the pump. I am at my wits end and would greatly appreciate any help I recieve. Thanks in advance......"
