Wow this is a long story ,Boat is a ski centurion tru trac 1982 pwc 351w , i replaced the raw water pump but did it incorectly and ran my boat for 2 min at 3 grand from the dock and the rubber exhaust started blowing smoke out the back and the temp guage creeped too only about 210 , so i shut the boat off and realized my mistake and fixed it , after a hour i tried too re fire but no spark.....* I noticed the key was left on and must have killed the coil or igniter kit in my distributor, so next morning new coil , no spark , so the igniter unit must have died , but no luck on back order..... so i went and bought a msd pro billit unit and installed it ..... boat idles wicked and sounds strond , set timing too 8 deg initial at 800 , removed vac advance and locked mechanical out at 25 deg total for a total of 33 deg ..... used the heavy springs like the stock one used... on the water it idels wicked , anything over idle it surges like 350hp 150hp 350hp 150hp and then over 2000-2500 pop pop pop out the carb ???
*So i pulled the heads and figured head gaskets , maybe cause there was no water in block motor got hotter than i thought , looked fine..... planed heads and re assembled motor new head gaskets intake ect fires up runs great so went too lake and less backfire maybe only 3-4 but over 3000 rpm and surges the same like 200hp 350hp 200 hp 350 hp .....
*i am very very mechanically inclined and checked the timing chain play cause i figured maybe it jumped a tooth but only 1/8 inch of play on the ballencer so thats great , re checked firing order 10 times cause dam it seems like 2 wires re crossed but no , when i did the initial timing i had a good backfire so i thought it might be the carb , maybe power valve or low fuel pressure ????? I lost all my tools in a fire so im limited on what i can do , should i buy a compression tester? If i cant figure this out im having a boat fire
