"I have a ’84 Ski Supreme with
"I have a ’84 Ski Supreme with a 351cu PCM (pre electronic ignition). When I went to de-winterize it I found that as soon as I connected the battery, the starter started to crank. I thought the ignition switch was bad so I took it apart cleaned it up and put it back together.
It was only then that I found that I have the same problem even without the ignition switched wired in. All 3 wires disconnected from the ignition (key switch) and as soon as I connect the battery the started cranks.
Any suggestions?"
Any suggestions?"
