I recently acquired a '73 Evinrude 18 hp that was seized and said to have been stored under a porch for who knows how long. I did get it moving again and believe it is worth trying to save. The main issue I have at present is the amount of Oxidation or White Rust that exists on at least half of the power head and lower cowling. It doesn't appear to be the result of salt water use as I've pulled the head to get things moving and the water jacket appears to be normal/clean. This condition limited to everything within the engine cover.
Is there a method of dissolving / removing this white substance short of bead blasting, or a chemical bath that would not require complete disassembly? A wire brush works on areas that can be reached but thats minimal. I've searched around on YouTube and it seems that Hydrochloric / Muriatic acid works but not sure I should chance using such chemicals on assembled motor. Anyone have any luck removing this stuff?
