OX66 V250 No Spark
johnnyhawk
"My new neighbors boat. Had no
"My new neighbors boat. Had no fuel to the rail (but had spark) Cleaned the High pressure pump and housing, screen. Now, I have fuel to the bleeder valve on the return...but no spark. I have checked the fuses. Battery is fully charged good crank. What is the ECM dependent on to send a spark signal? Can I flash the ECM and remove any error codes? Any way to set it to a default mode and run? Without the mannual and some wiring diagrams I am looking for some checks I can make to eliminate suspects. I did make sure the lanyard was connected to the kill switch by the way. Any help would be great. Thanks very much.
John
Seminole FL"
"unhook your main wiring harne
"unhook your main wiring harness and jump start motor to eliminate SHIFT BOX, NEUTRAL SAFETY SWITCH , BAD EMERGENCY SHUT OFF SWITCH
just a quick test to see if its that they short out and go bad quite frequently"
"just unplug the white wire fr
"just unplug the white wire from CDI box
watch out though, you will not be able to shut motor down"
