i have a problem with my ox66 250 outboard (2006). The engine is turning over and has a spark on all 6 plugs, but the pump is not activating and injectors are not opening. All fuses are intact.
i have directly fed the pump and it is working fine. i have also checked the injectors with a separate feed and they are activating.
so far, all i have come up with is that the main relay may be at fault. does anyone know the best way to test the main relay.
Or, is it be possible that the CDI has failed? even though the ignition side of the CDI is working fine.
Roger
Roger
