"This is a 1996 225HP Carb mar
"This is a 1996 225HP Carb mariner outboard. After getting on plane, temp gauge will rise to 3/4 then the alarm sounds. When this happens, the ECM does not retard the ignition to 3,000 RPM?
The last time the horn sounded, I immediately went to the P-tube outlet and felt the water. It was warm, but not hot. I pulled the cowling off and checked the head temps with a laser temp sensor. The temp's ranged from 165 to 175. ?? I could touch the thermo housing and heads without being burned? I replaced the four lead electronic temp sensor and I'm still getting the same results? Could it be something in the electronic control module? Thanks WJH"
