I am starting another thread since we are moving into part 2. All the history is on the previous posts and thank you for the assistance you have provided. Went to the boat today for dock side tests and learned a lot. To review the situation: Pursuit 3000, 5.7 liter Captain's Choice, 1992, fresh water cooled, 300 hours, overheat on starboard engine, sometimes shows on gauge, sometimes on alarm with no over temp shown on gauge (sensor for alarm is on the other side of manifold). In the course of treatment have had trained mechanics install new raw and fresh water pumps, new thermostat, cleaned heat exchanger, new belts. I discovered belts were incorrect and caused pump slippage (twice, put on by two different “Crusader mechanics”) and that the seat for the coolant cap had a ding that allowed an air leak, so that gas could exit while running sea trials, and that coolant did not feed back in on cooling. These two issues are resolved, but they interacted with the third, mystery issue and have caused some very conflicted data.
Overheat shows up as a hot spot in the front of the engine by #1 cylinder. Entire engine seems nominal (160) except there where I read 210 on the surface of the manifold. Since that is near where the ECU sensor is located it sets off the alarm. Gauge sensor on other side is fine now that fan belt slippage is resolved. Everything pointed to a combustion leak as the third issue. Tried a combustion gas detector today. Engine overheats quickly in that corner as rpm are raised, lots of bubble and boil....but no combustion gas. (I think that is good news). So I must have some sort of a blockage that is allowing very low coolant flow to boil in that corner, even though 8 inches away the gauge sensor (and my IR reader) show normal temps. I look at the diagrams and realize that the water pump has two exits into each side of the block, and the overheat is by one of the exits. And while the area around #1 is overheated, moving a few inches back on the engine is seems to be gone. So I am thinking some additional coolant must be coming over from the other side of the block. (Can someone help me here, does that make any sense?) The casting temperature over thermostat housing (located on the front in this engine – does not agree with my book) is at 160, pipe at rear of the engine into heat exchanger is 165-70 or so, Exhaust manifolds are around 170, risers at 95, in short everything looks OK.....except for the hot spot.
So I am thinking I will take the new water pump off and see what I can see...maybe a crooked gasket or something blocking an exit. My boat partner (who is too tall to fit into the engine compartment) says try taking out the thermostat. Now the coolant flow is (I think) from the water pump into the block and heads (where we have the problem on that one side), then back out the front to the bottom of the thermostat housing, then though the thermostat and out to the exhaust manifolds, then to the heat exchanger and back to the water pump. The thermostat is downstream of the “blockage” so how can taking that out help? Plus I had received two face fulls on coolant already and was not in the mood for suggestions. Still, I tried it and problem gone! (sort of). Temp in the “hot spot” gradually climbed to 180-185 (not the usual 210), then I check the temp into the heat exchanger and it was at 185 as well (not the usual 165-70). We kept the rpm cranked up to around 2500 and then suddenly the temps dropped everywhere to the 150 to 160 range. Then my IR sensor ran out of battery and I could not take any more readings. But all seemed good and we did not get an alarm.
I took the thermostat home, as well as the one that was originally taken out and replaced. Both open as designed at 160. They are not the problem, but maybe taking them out relieves the symptom. Or maybe taking out the thermostat relieved some back pressure on the water pump and it pushed though (to somewhere) whatever was blocking that flow in that location. That could account for the apparent temperature drop before my IR thermometer ran out of juice.
Sooooo, tomorrow if I put a thermostat back in and everything is good, then I guess I assume I had a blockage and it is cleared, and hope that it does not come back, or lodges where is does not matter, or the water pump ground up whatever it was, or whatever. I can't pull the engine to look for something that seems to be gone. That is an easy choice.
If I put in the known good thermostat and find that the overheat comes back, I guess I have a mystery blockage. I can check the water pump exit for something obvious. If that does not pan out, then what? The engine temps seem fine without any thermostat, and I guess one would assume the higher flow without having one in there is allowing enough coolant to reach my old hot spot in the front corner of the engine. Or is this being overly optimistic? Do I tear into the engine, or just run without a thermostat? Does anyone know of issues associated with coolant not circulating correctly if the thermostat is absent? Winter down here might get down to 65 so cold weather operation is not a problem. Clearly the thermostat is, even when open, a big restriction to flow compared to an empty hole so this could change flow paths significantly.
I will let you know what we find, but suggestions and ideas are welcome. (Partner says leave it all alone and lets go fishing, we have missed too many days already!)
Happy New Year (and I am really glad I will not be pulling the head of the engine tomorrow!)
CaboJohn
CaboJohn
