"Hey guys whats going on. I ha
"Hey guys whats going on. I have a 1970 FWC 318 with the sherwood double pump set up. As soon as the engine warms up she starts to overheat. I used a laser temp to verify this. I have great water flow coming out of the exhaust so I eliminated the raw water pump and system. I changed the impellers in the double pump,had the heads checked and serviced, replaced the head gasket, cleaned out the cooling ports, no thermostat at the moment, primed the double pump, heat exchanger is pretty new, ran fresh water through out the whole system to make sure there was no blockage, you name it I pretty much tried it. I did take one hose off that runs from the bottom of the double pump into the thermostat housing and had nothing coming out. Also would anyone have a diagram on the FWC system with the double pump sherwood? Engine starts up fine, runs great, idles in gear at 700 rpms so I'm assuming the timing is set properly. Any ideas would be much appreciated. I even had another marine mechanic look at it and he was dumb founded.
Thanks!!!"
Thanks!!!"
