"I'm stumped. I'll try
"I'm stumped. I'll try to hit the facts: All started after dropping the lower unit to repalce a shift shaft seal. Changed the water pump also.
Temp at idle is fine. Between 3,400 - 4,000 rpm, engine temp will slowly climb to 1/2 then 3/4, then alarm. Drop to idle then comes down to 1/4.
Yesterday just befor temp hit 3/4, I opened it up to max 5,500 rpm and temp dropped from 3/4 down just above 1/2. I have changed water pump again. Inspected water pickup gromet.. good. Checked P/Valve.. looks fine. Took thermo's out and flushed down. Put hose on remote flush tube, heavy flow out of thermo outlets. Temp on this motor never ran over 1/2. ??? Thanks.."
