Hi guys greetings from Greece.
Recently I became the owner of a 12 meter Trojan Express model 89 with DD 671 J&T 450 HP. When I bought the boat the engines had 850 working hours. From the beginning the temperature of the starboard engine was about 15 degrees Fahrenheit higher than the temperature of the port engine. Lately when I am cruising at 2.100 RPM the temperature rises to 185 degrees Fahrenheit and if I press harder 2.200 RPM it rises even more. I’ve noticed that cooling water is coming out from the expansion tank.
Any ideas what I should look for? Please also let me know which is the appropriate RPM to run the engines. The constructor says 2.200 but they seem a lot to me.
Thank you in advance for your replies.
Sotiris
Sotiris
