"Sorry for the long explanatio
"Sorry for the long explanation, but I want to be as thorough as possible. Did a bunch of work to fix the lack of rpms on the starboard engine (gas filters, plugs, wires) and when I fired it up and left the dock I saw the temperature gauge climb to 200+ and of course the rpms would not go over 2800. I shut down the engine and saw coolant coming from the radiator cap area (found out later that I have a crack in the neck of the radiator/heat exchanger). When I took off the cap a lot of coolant bubbled out which I expected. I then filled it with water (had plenty since I was in a Great Lake) and left the cap off. When I ran it, it started to bubble out again from the feed line to the pump. I expected to see water circulating from the return lines but none was visible. I then removed the thermostat, but that was fully open and ran it again with the same result. I then refilled it with water and tried it with the cap on. To my surprise the temperature dropped to 160 and the rpms went up to 3600 (which was more than usual)but then coolant started spraying out of the crack at the radiator neck. The next morning I removed the internal water pump on the engine block, but it looks great. I also removed the lines from the top of the thermostat housing and blew through them and had no resistance so I assume they are good. I have also removed the radiator and will take it to a local shop for repair. So some of my questions are:
Should I see coolant circulating through the radiator unit with the cap off? I am use to cars where the fluid will circulate with the cap off.
Does the system need to be capped and pressurized to work properly?
The pump looks great and has straight blades so that it can run in either direction, does this sound correct?
I am considering checking compression in all cylinders in case I have a head gasket leak. The head gasket was changed when I purchased the boat and maybe it wasn't done correctly. The rpm issue feels like a lost cylinder but sometimes it kicks in and runs fine until I stop and try to restart.
I am almost at the point where a replacement long block may be the best fix.
Thank for all the help,
Jeff"
Jeff"
