Overheating 1971 55hp motor
eaglepacker
The warning alarm under my das
The warning alarm under my dash goes off sporadically and I traced the wire back to the engine and I guess it's for overheating....How do I prevent it from overheating? Can you guess this is my first boat?
"First thing to check, is it c
"First thing to check, is it circulating water.
If you havent bought a manual yet, I would suggest getting one.
Josh C."
"You need to:
1. place it in
"You need to:
1. place it in a barrel of water if its small enough
or
2. buy one of thoes water muffs, this allows you to screw in a garden hose to supply water to your engine
then crank the engine and see if water comes out the top exhaust port. (make sure you turn the water on first)
Josh C."
"Water comes out when I'm
"Water comes out when I'm idling...not sure when I got the throttle down....too busy steering!
Nother question...the boat doesn't have a power trim, nor a manual trim as far as I can see...does anyone have a pic of a manual trim so I can see what I need?"
Is there a bar that the motor
Is there a bar that the motor sits against?
it would be horizontal and probably go through a hole on either side of the the motor mount.
This would have several sets of holes to allow you to move the bar toward or away from the back of the boat (Transom).
Josh C.
