"I run a pair of Crusader 5.7
"I run a pair of Crusader 5.7 320 HPs with 425 hours..FWC. At 3000 RPM, the port engine temp is 170 but when I throttle back to idle or slow speed it climbs to over 200. I have strainers which i clean. I repalced the raw water impeller twice. I had the end caps removed from the heat exchanger and flushed out bits of an old impeller and there is plenty of flow. It seems that there is little or no water coming out of the exhaiust port during idle speeds. The riser was checked. I also flushed the entire cooling system out with RYDLYM. i am running out of options and funds. Any thoughts would be appreciated.
Scott"
Scott"
