capn_morgan
"Got a 1990 Evinrude 70hp that
"Got a 1990 Evinrude 70hp that the temp alarm is going off. It pees a steady stream out the telltale and I can take the cover off and put my hand on the exhaust cover - it just doesn't seem hot. It will run forever under 3000rpm without an alarm and it hasn't alarmed at 5400wot (although it doesn't run much there as it's a pontoon boat.) But around 3500-4000 it will occasionally go off. Let it sit a minute, it starts right up with no alarm. One time we were docked at a buddy's place for about 15 minutes and when I took off, it alarmed within 30 seconds. Doesn't seem long enough to even get warm, much less hot. I did replace the temp switch with a new one and it still happens. Could it be wiring and the vibration at that rpm sets it off? Is it possible the top carb is running lean at midrange since the switch is on the top cylinder? I do have carb kits for it, but prolly won't get them in this season since it's almost over around here. Any thoughts?"
