the_stranger
"e recently purchased this mot
"e recently purchased this motor and the test run and subsequent outing were all good.
Then the problems began.
First off was the overheat alarm going off. Flow from the pee hole was good. We pulled the cover to feel the head temp and noticed the fuel primer solenoid leaking. Upon return we pumped the fuel bulb as you normally would and noticed leaks fuel leaks from the fuel line to each carb.
Whilst repairing these we noted the each spark plug was loose.
Our thoughts were 1) we were lucky as fuel leaks and sparks are not a good idea and 2) a lean condition from air ingress about the spark plugs and into the fuel lines causing increased temperature.
So remedy this and fire it up in a bin. Ran it for ages - no problem.
Take it out and it overheated again.
So, water pump still looks strong from the pee hole, it must be thermostats right?
Remove the thermostat housing and bingo - someone had replaced one thermostat in the past but not the other. The old one came out in bits.. Looked to see if any bits were unaccounted for or lodged anywhere visible, couldn't see any.
Re-assemble and run it up. Great - unless we go over 4000 rpm, in which case the alarm goes off after 3-5 minutes.
If we stop the motor and immediately start it again, the process resets i.e. can run it all day under 4k or if taken above 4k alarm goes off again after say 3-5 minutes. Stop the motor and restart it repeats the process
Sooo. Where should I be looking?
Alarm system or is there some way to test flow around the block?"
