firedreamer
Ok need tips on clearing a air block in the fresh water side of new rebuilt 454 gen4s have great raw water side, about 5gal flow in45-50 sec at 800 rpm. along with rebuild on longblocks i have also replaced with new the trans/oil coolers. freshwater pumps, oil lines from remote to cooler and block and all risers & elbows on both eng. manifolds looked pretty good so kept them. The heat exchangers both are clear and wide open on raw water side of tubes and new thermostats last summer. i opened the vent on thermo housing when filling for first time with 50/50 antifreeze as directed by service manual. At the start of all this the return hose from HE back to water pump was cold to touch but after running and opening vent again now it warm to touch but temp gauge still shows over heating? on both eng timing is good also new temp senders. Any tips or other thoughts ?
Also how high a temp is to high even for a few min to get to before shutting them down and waiting for them to cool before next try ? THANKS ALL
