"Hi everyone, I posted last fa
"Hi everyone, I posted last fall with this same problem. After replacing everything fuel related and spark related on the boat the problem is still the same.
I have a 1986 Bayliner Trophy with only 300 hours on it. I get it underway and go about a 1/4 mile and the plugs foul and I get a measurable amount of gas in the oil pan.
I have replaced EVERYTHING fuel related with new parts. I also replaced the distrib, coil, etc etc. Everything is in spec.
I need some good advice. It's a 260A small block chevy with a volvo penta set up. Rochester Qjet on top. I can turn both mix screws in to the bottom and the engine will not change pitch or die. Almost seems this thing would run without a carb at all. I had the original carb rebuilt twice and the put a brand new one on it to eliminate the idea that it was the carb. No Joy, same symptom.
Help"
Help"
