I changed the head gasket on a 70hp 1990 Evinrude, cleaned everything spotless and applied Permatex Avation liquid to the bolts and installed in sequence and torque specs of Evinrude manual 18-20 ft lbs. I tested the engine in the tank and had a small leak out one of the bolts. I ran the engine for a while but it did not seal that leak. So, I went back and torqued it to 23-24 ft lbs. while it was still hot. The leak was less, but had not stopped, so I turned off the engine and called it a day.
Should I go back and remove the head and put some sealer on the head face where it leaks from ( I think there was a ding there), or apply some JB Weld? Then torque cold to 20lbs.
Should I loosen the bolts now, so the gasket does not get over crushed by the extra lbs of torque? Will the gasket be re-usable at 20lbs?
I was going to just run it as it is to see if it seals with time and heat.
What do you ME experts say?
