[FONT="]I have a model year 2000 200 EFI Mercury outboard. This past August I was on Sturgeon bay and the water temp was in the low 70s. I was just cruising along a about 3000 RPM and the over heat warning horn came on. I looked at the temp gauge and sure enough it was at about 210 degrees. The motor was peeing well and the water pressure gauge was reading about 12 psi at that 3000 rpm.[/FONT]
[FONT="]I replaced the thermostats and the water pump and had it out on a local lake with a water temp of 57 degrees this past week to do some testing. Ran a mile or 2 at 3000 RPM and the temp gauge again read 210 degrees but the warning horn did not go off. Probably just short of tripping due to the colder water.[/FONT]
[FONT="]Running at ANY other RPM will cause the motor to cool off. I can run miles at 4000 RPM or at 2000 RPM and the engine stays cool(145 or so).[/FONT]
[FONT="]Looking for any ideas.[/FONT]
