Hello Everyone, continuing with my engine rebuild, Volvo Penta AQ231 A, 1989. Engine is running smoothly, how ever; every time I start the engine after been off for few hours the Temp raises to 180 plus within 7 minutes, and the red light temp flashes. Once I turn the engine off for 5 mins, I can then turn the engine back on and if I squeeze the water supply line (hose) from the thermostat housing to the circulating pump for few mins the temp drops down to 149 and stays there, the temp light continues to flash indicating a possible problem. I have removed the thermostat and tested, is rated at 140 and it does open at 140 degrees, I have run the engine without the thermostat and the temp never raises it all. Is it possible that the circulating pump has gone bad? is it normal for the hose that goes from the thermostat housing to the circulating pump to the hot all the time?
