Over heat horn
sticky
"hi last week replaced waterp
"hi last week replaced waterpump,tstats ran perfect all wknd,fired up on muff today,got hot,i noticed water out tell tale was skipping,usually steady stream,whats up,thanx everyone"
"LOOSE flushette,low water pre
"LOOSE flushette,low water pressure,kinked hose,too long of a hose line.,damaged impeller,dibris in intake."
"same flush and hose i always
"same flush and hose i always use,water did get warm coming out,can it be stuck tstats"
"i would look elsewhere...high
"i would look elsewhere...highly unlikely 2 new thermo's are bad...highly unlikely...now,if u stuffed them full of mud...................diff story........pull that flushette off,and squeeze it together real hard...it needs atight fit...turn water on fully....ck the inlet on the flushette for dibris...put your boat,back in the water before ,tearing into it..."
"jwb pulled tstats the valve b
"jwb pulled tstats the valve body had sand in the little hole in center,poke it out with a needle,would this cause overheat,also would i need to take lower unit off and flush,or and easy way,V4 X flow thanx"
"sand in that one lil hole was
"sand in that one lil hole was not ur prob...u can ck ur thermos if u want in a pan of wtr,they should be fully open at 143.i believe,..now,i would drop the lower unit,and ck that water pump.."
"ok dropped L/U everything loo
"ok dropped L/U everything looked fine,the only thing i see is little sand in ts housing,and tstats,what do you think,thanx"
flush everyting real good....p
flush everyting real good....pull the hoses off and ck on both ends that they r very clear.
Can you take the pisser out an
Can you take the pisser out and hook the hose up to that model to backwash the water system?
I would take it back on the wa
I would take it back on the water before ripping it apart......it might just be lower pressure coming from hose.
"ive always used the same hose
"ive always used the same hose same pressure,i took it all apart,will replace whole water pump,the only thing i found was sand in tstats and housing,flushed everything,il put it all back together this wknd,i dont understand it i run it all last wknd broght it home wash boat,flushed motor with fresh water,put new tach on fired ir up on muffs idle 5 min. later running hot i shut it down,so thats all i got, thanx"
You seems to 'walk about&#
You seems to 'walk about' not quite knowing what is happening.
There are 2 temp switches -does both react or just one?
Invest in a heat-gun and do a more exact analysis of the problem.Where is the 'hot spot'? Might be cheaper than just buying and adding parts on random.
Get a bucket and skip the muffs until You have solved the problem.
"I've had sand clogged so
"I've had sand clogged so bad it was packed in the pisser, no water was coming out, and I had to jam my finger in it a few times to break it up enough to get the hose connected. It was also packed half way up the water pressure sender hose. There was so much sand that I couldn't go over 1500 RPM's. After I flushed it out, It ran fine, with little traces of sand in the tstats. I'm sure if you just had some sand in the motor the pump is fine. Maybe with that new pump, it isn't sucking water from the muffs as well as the old pump did."
"well horn went off both heads
"well horn went off both heads hot to touch,the pump worked fine till this past wknd,i cleaned the tstats,tested them,flushed the motor put new water pump in,and il put it back together this wknd,i havent had any problems till now,and ive always used the same muffs same hose same pessure,so if this dont fix im lost"
