Hi, I was on my boat the other day and noticed that none of the outlets (3 of them) work, when the last time I tried them they all did. These are the AC outlets that run using shore power and the AC utility panel, which has a switch for them "on" and "off".
So, there's the AC main switch, and then below it, an "outlets" switch. The boat has a converter too, but the outlets should be hot even if it's not turned on.
Are bthere fuses as well as breakers in the main AC panel? What is maybe going on here? Thanks, Pal
