Outdrive Problems
C
Chris Edmondson
Guest
"First off I may have messed u
"First off I may have messed up, I changed from a left hand to a right hand prop, I changed the lingage around. On the first time out I developed a metal to metal grinding that sounds to be coming from the clutch area. This is a 1983 Bayliner with the 4.3 and 270 or 275 outdrive. I have oreder a manual, thought I would see if there is any advise for me. Thanks"
"What do you mean, clutch area
"What do you mean, clutch area? You may not have got the prop on right and are scaping the lower housing with the prop."
