J
jbell0565
Guest
"Anyone help? 1987 Bayliner Ca
"Anyone help? 1987 Bayliner Capri. 2.3 OMC Cobra. Motor was knocking "bad rod bearing" removed the outdrive to pull out motor. The outdrive came out no problem. Took all of 5 minutes. Removed the motor, replaced rod bearings and reinstalled. Used the alignment tool and aligned the motor. Went to put the outdrive back on and it just will not go in!! It gets as far as the outter most ujoint houseing and makes contact with the u-joint bellow and will not go in past that point. I've done everything according to the manual for reinstallation. It's not making contact yet with the flywheel"spline" receiver on the motor, so I don't think that's the issue. It's as if the rubber bellow "shrunk" and isn't big enough to get that knuckle thru."
