Outboard Shaft Length
lambster
"I have been "coached/dire
"I have been "coached/directed" to determine the correct shaft length of my outboard by measuring the length from the top of the transom to the bottom or keel of the boat. My boat has basically a sea drive that makes this difficult. I have seen engines listed for sale that are supposed to be 25" and they have the lower unit bolted directly to the exhaust housing. Mine has a 5" high spacer housing between the exhuast housing and the lower unit. I don't think I have a 30", but I am confused as to how to determine what I have based on engine measurement rather than boat."
The cavitation plate needs to
The cavitation plate needs to be about an inch below the bottom of the boat. Just worry about that--its' all you need.
jeff
"John, the 5 inch spacer is si
"John, the 5 inch spacer is simply a spacer and could just as easily be seen on any outboard. If you have a short shaft outboard, a 5" spacer (with a water tube and driveshaft extension) will turn it into a "long shaft" model.
Are you looking to measure to see what you would need to replace the SeaDrive with an outboard or are you looking for a measurement on your unit itself.
Measuring your transom will tell you what "shaft" length you need - 15-17" is short, 20-22" is long, 25-27" is extra long and above that is the more recent 30" shafts (which I don't know the name - extra extra long or super long???)
When measuring a motor to determine what it is, the diagram below is the accepted standard.
