Outboard locked.
bigman1
I have year 2000 40hp mariner manual start outboard, pull start won't turn over, took out spark plugs turns over fine,put plugs back in won't turn over. Can anyone help. Thanks.
Was there fluid in the cylinders (i.e Fuel, water, etc.) Be sure and check.
With the plugs out you can easily spin the flywheel - did you place a stick in each plug hole and verify the pistons are ll moving back and forth??
Any chance that when you prime it /or the fual pump is flooding the carbs into the pistons/crankcase?
Exhaust blocked?
