Hello all!
First off, I would like state for the record that I know very little about outboard motors.* So, here is my problem.* I was out on the lake a couple of weeks ago and could not get my motor started.* Under the hood, I found a little red valve that, when turned, dumps all my fuel back into the gas tank.* It may be just me hearing things, but it also sounds like air being dumped as well.* I've asked around a bit and vapor locking is the response I seem to get the most.* Could this be what it is?* If so, how do I fix it so I don't have to play around with what I believe to be the intake manifold every time I want to use the outboard?* I know that my fuel mixture is good, with a ratio of 4:1 , and I only use premium unleaded.* I had read somewhere that I shouldn't use high octane gasoline, but everyone I talked to said to use premium with no ethanol, so I don't believe this is the problem. My motor details are:
Make: Johnson
Model: J70TLCUR
Year: 1987
Any help or useful advice would be greatly appreciated as this problem is very annoying.* Thanks!
Make: Johnson
Model: J70TLCUR
Year: 1987
