Outboard jet owners check this out
L
Lou Dreisch
Guest
" If you own an outboard jet e
" If you own an outboard jet engine you may be interested in this product.I have been using the Jetfins for 2 years now.I go nowhere without them.Best investment I ever made for protecting my lower end ,plus giving me performance bonus's.
WWW.JETFINS.COM "
I RECENTLY BOUGHT A 150GT JOH
I RECENTLY BOUGHT A 150GT JOHNSON 86 MODEL A COMPRESSION TEST WENT 90LBS 80LBS 80LBS ON THE LEFT BANK AND 80LBS 80LBS 50LBS ON THE RIGHT IM AFRIAD I MIGHT BLOW IT IF I RUN IT MUCH MORE IT IDLES AND RUNS GOOD THOUGH ANY THOUGHTS THANKS
" Eric67,
Sounds like the pi
" Eric67,
Sounds like the piston ring(s) went out on the low comp. cylinder, most likely, usually due to water intrusion, either thru the head gasket, or excess water in the fuel or even oil(if it has injection). Or if it has lots of carbon build up, possibly the rings are stuck. My advice is to pull the head on the low comp side to see how the cylinder wall/piston condition. "
