Na8en101
so while I am waiting for the reeds I have not had a chance to pull the boat out to pull it apart , so I have rebuilt the carbs, did a whole link and sync, replaced all fuel lines , new fuel pump, new water pump and impeller , fixed the timing , replaced all spark plugs , have done spark test jumps half inch, compression test within normal , might be a few other things that I have forgot to mention, but it is a 1977 evinrude 85 hp 85799s, it ran great and was idling well when I was running seafoam through it , ran good for a little but and then returned to this state where it is hard to start will not idle , and if it does it will die soon after , there appears to be fuel on the bottom of the cowl, it will run at higher rpm, not great , but will run, seems to sputter sometimes like it is missing a cylinder that almost kills the engine otherwise you pretty much have to spray starter fluid to get it started, yes I replaced and gapped the plugs after seafoam, does anyone have any suggestions if it turns out not to be the reeds sorry this is all that has been on my mind I just want to be able to go fishing and take the family out on the lake, any suggestions or observations is appreciated, also I gave to replace the impeller again because my dumbass cousin ran it at a high rpm outside of the water , and the overheat alarm will go off if you out it in gear and travel a little bit 50 feet or so also replaced vernatherm
