Original prop size needed
willmach
"I have a AQ130A with a 250D l
"I have a AQ130A with a 250D leg, what i am looking for is information on the Drive?leg.
I am running a 14 x 19L ali prop and not sure that this is the original.
What i need to know is the drive ratio and original prop size, so if anybody can help it would be appreciated.
If anybody requires the manual for AQ130 A,B,C & D send me an e-mail i will be happy to forward it."
"The drive should be a 2:15 to
"The drive should be a 2:15 to 1. The prop is anybody's guess as new drives don't come with a prop. They are put on by the dealer after the engine package is placed in the boat. The 14" diameter props are normally used on the 4cyl, so you're ahead of the game there but to prop it right it needs to go to the water and tested with different pitches. Not knowing your boat a good place to start is 17P and work from there. What's the rpm's now with the 19"?"
"Have not been able to test it
"Have not been able to test it yet, i need to straighten out the existing prop and put to water,this wildcat was bought as a project with the intension of returning it back to mint condition"
