Hello,
thanks for the info, i have replaced the fuel hoses, ball pump and rebuilt the carborators, and replaced the diaphram, and then tried to start up motor to tune the idle screws but now it does not start at all, i sprayed engine start into the carbs and it started up few a few seconds, i then took the fuel line coming into the engine and pumped the ball and gas is coming into the fule pump, then i took the fuel line coming off the fuel filter line going to the carbs and tried starting but nothing coming out there, is there supposed to be flow?
my question is why all of a sudden no engine start at all after all i did to it? when the original problem was no high speed when i started? any insight??
