"Recently bought a used wellcr
"Recently bought a used wellcraft with a 1995 Mariner 90 hp 2stroke serial #6086959
Can't seem to find a place to get original manual??
so Winterization here in the Northeast- checked the site and came up with this
1. Run 15 minutes to warm up with fresh water and treated fuel (stabilizer with ethanol treatment.)
2. Drain lower end oil, inspect, inspect o rings/replace if necessary, fill up from bottom with quicksilver premium gear lube, close (How much is capacity?)
3. Fog caburetor till stall.
4. Remove plugs, pfog, turn a few times with wire off to distribute oil.
So far, I have seen nothing about water/antifreeze.
Are there any other suggestions?
Thanks for the help."
