My 2001 Opti starts and idles fine. At crank the TPS fault shows briefly on the Smartcraft gauge, horns sounds momentarily and then shuts off. Advancing the throttle either in neutral or while engaged causes the motor to run extremly rough, sputter and stall above approximately 1200 RPM. It will motor around without symptoms but moving the throttle above 1.2Kish initiates it. New Racor, motor mounted gas filters, primer bulb, plugs inspected and run on a portable tanks. Same results. Will the TPS cause this problem? What should I check / eliminate to narrow down the problem?
