DavidW2009
Here's how I back flushed a 2.3L Cobra.
Test Fixture:
1/2" Threaded (one end) PVC Schedule 40 Adapter, Lowes Item #23861 $.50
1/2" NPT X 3/4 FHT PVC Swivel, Lowes Item #194638
$2.00
1/2" X 4" PVC Pipe
$.10
Total $2.60
Glue 1/2" X 4" PVC Pipe into Adapter. Thread adapter, using Teflon pipe thread tape, or glue, into Swivel (has female connector for a garden hose).
Insert pipe section into hose that comes from the transom, via the P/S cooler.
Connect garden hose to swivel and turn on water.
I use a 1/4 turn plastic ball valve 'Y' attached to the end of my garden hose. That way I don't have to walk 100 feet to the outside faucet. That is the yellow thing in the photo.
I ran this back flush several times and got what I think is good flow out of the intakes. (see photo). (I'm running this off of a well with (50) PSI, about half of what city water would be.)
Question: Is it normal for a small stream of water to come out the center of the prop when back flushing? (See photo)
While back flushing, I removed the outside cover on the Cobra to see if there were any leaks around the impeller housing. Sure enough, there was a small drip, which would probably suck air during normal operation.
Test Fixture:
$2.00
1/2" X 4" PVC Pipe
$.10
Total $2.60
