29' Phoenix with twin 350' crusaders. So I was in the water brushing down the hull of the boat today and while scraping off the two or three barnacles that had just started to develop on each prop*I noticed that the starboard prop*turned by hand*quite freely while the port required a bit more effort and made a slight squeaking sound (underwater) when I turned it. Both engines were in neutral. (and obviously not running)
Engines run fine though I did notice a very slight RPM bounch on the tach while running home. (+-50-75)*Got back and*felt both shafts, not hot at all. Is this a concern and if so What would you check first? Bearings?*****
