S
steve hale
Guest
"Boat = 29 phoenix, twin crusa
"Boat = 29 phoenix, twin crusader 5.7 carbed power pack 300hp. This problem began after repower. Prior to repower, rpms wot were the same.(4200)with 270hp. Props just reconditioned and bottom clean. One engine will get to almost 5000 the other 4200.( the manual says 5000-5200 by the way, which seems awfully high) I thought it would correct itself after break-in, but has not. The engine that does not tach up requires more throttle to get to the same rpm, thus being less efficient on the floscans. The boat starts great, runs great, just one engine isn't as strong. I have not compression checked. The timing marks on both engines seem way off. On the strong engine, we had to time it by "feel" and adjusted forward until the spark knock and backed off until it went away at 4000 rpms. My theory is that the weaker engine timing is slightly retarded. I've never messed with the timing on the weaker engine since it has not any problems except being a little weaker. Should I compensate for rpm difference by pitching one prop more than the other?"
