OMG i blew my 151a
tlacey1
hi all ok i have done it now
hi all ok i have done it now i was cursing at 21 mph rev about 4600 on my 22 sun runner and it just blew.now what to do can i replace with a b240 car engine by changing my crank exc or where is a good place to find a 151a short block?????
"Hi Tom, can you provide a bit
"Hi Tom, can you provide a bit more information as to the damage to your engine? Some damage can be fixed w/o replacing the engine.
Tom"
the #4 piston connector rod ca
the #4 piston connector rod came through the block and blew the starter off. i have a good view of the inside of the block. not fixable
"By golly Tom, I believe you&#
"By golly Tom, I believe you're right!
Tom"
"Not a new one, have seen that
"Not a new one, have seen that several times. Normally it may happen after a previous water-lock of cyl 4 due to slipping cam-belt, bad manifold etc. You may consider yourself lucky in a way. I have seen cases where the starter/block parts hit and crushed the carb, fuel down on the battery cable, and ***************!!"
pulled the engine today put on
pulled the engine today put on a engine stand found the balance shaft broke near the #4 cylinder and got jammed in the crank/piston connecting rod and pop.anyone know ware i can find a used 151a????
