OMC trimtilt problem
zion
"I have an 800 omc stern drive
"I have an 800 omc stern drive. When i swich it in reverse, the stern drive raise up and i can't move
backward. }}"
"Your problem is in the outsid
"Your problem is in the outside (port) tilt clutch housing. It may be everything from worn out clutches, broken shaft or broken lock ring. Only way to check is to take it apart."
I have a1980 omc 400 with a 4-
I have a1980 omc 400 with a 4-cylinder chevy that will not tilt.
Also I have new motor(4-cy
Also I have new motor(4-cylinder chevy) with only a few hours on it but it runs hot after I reach higher RPMS.
