"Hello, have read one of the
"Hello, have read one of the long threads on this problem and it was very helpful. In any case last year had intermittent tilt problem as took several trys to raise stern sometimes. This spring I was getting the boat ready for summer and was able to raise the tilt once or twice and then nothing. A friend and myself have determined that there is 12 volts going into the tilt motor. I have since pulled the tilt motor and found that the shaft end with the cutaway was twisted and cracked down from the top about a quater inch. So the shaft with the armature is no good and will have to find an armature or whole tilt motor. But before I install a new motor I would like to know what caused the motor's shaft to twist and crack. I pulled the quadrant gear off and raised the drive. I wanted to see if the worm gear would turn. I was able to turn it from the slotted end inside the boat clockwise but wasn't able to turn it freely counterclockwise from inside the boat or so I think. It was difficult to do that test as it is hard to get at and to even see what you're doing. Is it possible that the clutch pack would be binding some how? I haven't taken the cover off but have sucked out most of old oil and put new oil in. I have read the posts about putting grease in the clutch housing so should I pull the clutch cover off and check it out before I install a new motor? Any input on this would be greatly appreciated.
thanks."
thanks."
