"My System check (tach)
"My System check (tach) intermediately, and randomly seems to go through its reset sequence while running; one beep, and all LEDs on, then each LED shuts off. This seems to happen about one or two times a trip, but the last trip, it started doing it continuously, about once every 5 seconds. At the time I was in fog and in the inlet, so I continued to run. After about 15 minutes, (seemed like 4 hours) it just stopped doing it. I didn't shut the motor off until I got the boat on the trailer. The motor ran fine the entire trip at all speeds. When I flushed the motor back at the house it ran fine, and did not reset at all.
My gauge pack was purchased about 2000, and my motor is a 1986 175 EVN. It is connected with an adapter cable, and the system has always indicated faults correctly, when tested.
While running (at home), I tried to wiggle the wires on the back side of the gauge, at the motor,and between the adapter cable connectors, to see if I could make it happen. It did not repeat. All connectors are clean and dry."
