Hello i have an omc stringer 400 from ±1984 with some issues. Have made a video.
https://www.youtube.com/watch?v=S35iFOgPEj8
I am a beginner mechanic and don't know where to start and fix this step by step. Read some of forums to take off the lower unit to check the shift shaft. But can't find something where to start step by step (beginner)
Issue 1 - Scratching lower gears (following by issue 2)
Issue 2 - Shift cable adjustment, after going in gear, 2 sec of scatching and then goes into gear. Forward throttle, forward conversionbox = reverse prop
and vice versa. So cables are connected opposite
Issue 3 - Sissing sound from Air filter / carburetor
Issue 4 - Yellow oil in the lower unit (mixed with lake water)
Did you have got the same or some of these issues? Any help would be welcome. Appreciate it!
