OMC Stringer 400 problem
Rich B.
I recently acquired a 1980 16' runabout boat that has a GM 120 HP 4 cylinder and the OMC Stringer 400. Well the issue that I am having is the out drive will raise enough to break the seal to the intermediate exhaust housing while driving. You know this has happened when you hear the volume of the exhaust get louder and you start loosing RPM's on top end. I have to stop and lower the drive then off I go again. This consistently happens when taking off full throttle i.e. pulling a skier, etc. Is the tilt clutch assembly responsible to hold the out drive in the down position, and only allow upward movement in the event the lower unit hit something in the water while under power? I am wondering if the clutches need replaced or is there an area I should be looking at to fix the issue?
I'm not sure I understand this. It can't possibly raising in forward gear when the drive is trying to push it's way through the boat under power. I can see this happening in reverse but not forward.
hard to believe Gary, but they do tend to lift when you go over waves, even chop, or when you decelerate even slightly the drive will back away from the intermediate if the clutch is loose.
The OP say's "while driving" it does this. When it "auto trims" it should gain RPM's not lose. Something really different is going on here.
