omc sterndrive coupler bushing play
removed gimball bearing and inserted alignment tool into coupler . should there be any up down, sideways movement of the tool? used a 1/4 x 1 inch flat bar to see if internal splines or rubber bushing moved. The spline doesn't move in the bushing , but the bushing moves about 1/8 inch up down from the edge of the metal enclosure. There shouldn't be any bushing movement at all?
Conditional statement , if movement then needs new coupler?
