"Ok, I'm trying to replace
"Ok, I'm trying to replace the water pump impeller on my Leg, its aa 175hp model with Ford 302 engine. I've seperated the lower unit, what I think is the exhaust housing is off the upper, now I took out the 4 bolts holding on the impeller housing, but it wont slide off?? I guess the impeller drive shaft has to come off with it, it says in the manual to use a 1/4 punch and go through the top hold and drift it out?? I've tried but wont budge?? Do I have to disassemble the whole upper unit to just do this dang water pump????
Thanks allot
Will"
Thanks allot
Will"
