Hi! Been reading up un these forums the last couple of days, and as I feared the problems with these drives are plentiful.
My problem:
Water gets into the oil in the waterpump housing.
What have I done so far:
New impeller kit, with all seals, did not fix problem
Resealed complete upper unit at a local shop, did not fix problem
Changed housing, resealed this, did not fix problem
The housing passes both vacuum and pressure testing, but leaks when I get it in water and the engine runs.
I have had axles inspected as well, and they are in good shape. Also, I can put new oil in, run the engine at idle for one minute , and this will cause the oil housing to overflow with water. In other words it seems like the waterpump is pushing water into the oil somehow.
My local shop cannot seem to understand why this is happening, since it has all new seals, new impeller kit and passes pressure / vacuum tests.
Any of you guys have any suggestions on what this problem could be?
Thanks Fredrik
This is my boat, with the darned drive on it!
My problem:
Thanks Fredrik
