I recently purchased a 1985 20 foot cuddy with a 115hp OMC outboard. The engine would start only when the throttle is in the partially forward position (would not start in the neutral). I was able to take the boat out once but the engine would continue to stall unless the throttle was in the mostly open position. Then when coming back in, the engine stalled and would not restart. I was able to drift in the rest of the way with the dock insight. I have since changed the plugs, replaced the gas and oil but have had no luck. The starter engages and the prop will turn (if the throttle is not in neutral) but the engine will turn over. I have not changed anything else. I would rather not start replacing the coils and other components without knowing what the real problem is. Any help would be greatly appreciated This is my first boat. Thank you.
